try plugging your laptop in to a TV monitor using an HDMI connection your laptop may have the wrong resolution set up, you then may be-apple to fix the problem
have u download the 64bit drivers ? acer havent released windows 7 drivers for this model i recommend visting this acer link http://support.acer-euro.com/drivers/notebook/as_8930.html choose the windows vista 64 bit sound driver once downloaded install ,if problem still persists then uninstall the driver then reinstall in compatability mode for vista ;) (rite click driver then properties and select compatability then choose vista and run as adminastrator ) hope this helps
The power supply on the 8930g is on the left hand side an is not as shown in the youtube video recommended, it is easy to remove the cover over the jack (one screw) and solder the jack back into place (done it myself) hope that helps.
make sure you remove the battery first.
I went to the Acer Pan American site (http://gd.panam.acer.com/home/) and navigated to the aspire 8930g page for drivers. The 'drop-down' window allows you to select Windows XP (Pro or Home) and provides a list of drivers for you model laptop. Check it out!
The Acer I bought for my Son last Xmas had the option of producing a full set of recovery disks and a drivers disk. If you have this option and you have used it then you have a way back to a functioning laptop if you have problems with the O/S change.
Download the drivers you need for the laptop accesories you have BEFORE YOU CHANGE THE OPERATING SYSTEM. Do your change then install your drivers. It appears from the surface that you should be able to do this change.
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Every now and then, the CineDash media console on the Aspire
Gemstone Blue models freezes, turns off, refuses to work, leaves you in
locked out of the car in the pouring rain… The causes are endless, but
the solution is quite simple.
To reset the CineDash, remove the power cable AND the battery for more than ten seconds.
THANKS FOR THE ANSWER BUT THE SONY VEGA TV DOESN'T HAVE AN HDMI PORT.
