Carrier 38CKC060 Air Conditioner Logo
A
Anonymous Posted on Jan 04, 2011
I bought a programable thermostat and ,to install it, I neet to know what type of system I have: single stage heat and cool; multistage heat and cool; heat pump with backup heat; heat pump without backup heat; heat only; cool only. These are all the options. Thanks.
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 05, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953267
Points
6173
IT'S COOL ONLY MODEL..
I want a thermostat for a heat pump I can set the differential for heating and aux. heat strip
Single stage cooling and 2to3 stage heating thermostat. A 2 stage heat t-stat will/should have the option for a heat pump and aux heat in the installation configuration.
tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 • Heating & Cooling
tip
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that...
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
Specifications of the Honeywell TH8110U1003 Thermostat
  • Description: VisionPRO Touchscreen 7-Day Programmable 1 Heat/1 Cool
  • Conventional and Heat Pump Thermostat
  • Application: Gas, Oil or Electric; Heat Pump; Millivolt
  • Programmability: Universal Programming from 7 Day to Non-Programmable
  • Changeover: Auto or Manual
  • Color: Premier White
  • User Interface: Touchscreen
  • Switch Positions (System): HEAT-OFF-COOL-AUTO
  • Switch Positions (Fan): AUTO-ON
  • Power Method: Battery or Hardwired
  • Terminal Designations: R, RC, C, W (O/B), Y, G, S1, S2
  • Dimensions (in.): 4 9/16 in. high x 6 in. wide x 1 1/4 in. deep
  • Mounting: Horizontal
  • Electrical Ratings: 20 to 30 Vac
  • Frequency: 60 Hz. 50 Hz
  • Setting Temperature Range (F): Heat: 40ª F to 90ª F. Cool: 50ª F to 99ª F
  • Setting Temperature Range (C): Heat: 4.5ª C to 32ª C. Cool: 10ª C to 37ª C
  • Differential Temperature (F): 1ª F
  • Differential Temperature (C): 0.5ª C
  • Stages: Up to 1 Heat/1 Cool
  • Outdoor Sensor: Yes, optional outdoor or indoor remote
  • Remote Sensor: Yes, optional outdoor or indoor remote
  • Sensor Element: Thermistor
  • Currents (Heating): 1.0 A running
  • Currents (Cooling): 1.0 A running
  • Currents (Fan): 0.6A running
  • Operating Humidity Range (% RH): 5 to 90% RH, non-condensing
  • Comments: Selectable to and Heat Only or Cool Only
  • Features: Screen lock
I just bought a honeywell RTH2510/RTH2410. It states that if your old thermostat has Y1 WI & W2 stop and contact a qualified contractor. WHAT? how hard can it be, just need to know what wires go where?
Your system has 2 stages of heat. Therefore you should have a 2 stage tstat. The 2510 is 1heat/1cool, put your w2 wire in with your w1 wire, you will be fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
tip
Th811u1003
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Specifications of the Honeywell TH8110U1003 Thermostat
on Jan 15, 2010 • Heating & Cooling
1helpful
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
1helpful
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
2helpful
3answers
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
RTH7400 thermostat installed-screen display unlit-used page 10 wire installation. Used heat pump wiring-which does not show W2 and Y2 on heat pump schematic, so used conventional displayed W2 and Y2...
w2 and y2 are used for 2stage applications
w2 = 2 stage heat
y2= 2 stage cool
If your system is a single stage system, look for the y1 and y2 terminals. If the thermostat does not have y1 and y2 then you may have the wrong thermostat. As always, please read the directions carefully. Thanks!
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
