Question about Sony VPL-EX1 Multimedia Projector
I have sony vpl-ex1 projctor and i have also changed the lamp of the projector but it still shows me the same message like change the lamp. Please advice! Thanks, Pravin Bhavsar
    New Friend:
1.unplug power cord
2.plug back in and it should be in stand by mode.(red light on)
3.do not power on
4.on remote push RESET,LEFT ARROW,RIGHT ARROW AND ENTER(do it in less than 5 seconds)
5.after you have done this power on and go to menu and it should show lamp hours 0
6.if it didn't work just do it again, it took me a couple of tries.
Posted on Jan 06, 2011
6ya staff
SOURCE:
Sony vpl-ex1 doesnt turn on. no light nothihing. power input does work, i can hear it zapping power :). might have dropped from ceiling holder.. atleast it looks like it. im trying to get it work for my...
the filter cover sometimes gets distorted and the small plastic dimple which presses against the switch doesnt activate correctly, check the lamp cover switch also.
Jun 07, 2011 | Sony VPL-EX1 Multimedia Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Sony VPL-EX3 projector on/off switch flashes green then turns red and the lamp/cover light is orange. Does this mean the lamp needs replacing or could it be caused by some other factors?
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Jan 17, 2011 | Sony VPL-EX1 Multimedia Projector
VPL-EX1 Just bought it from someone the lamp is 450 hours, it worked fine with no message. no im trying to turn it on and it will just lift itself and lamp cover moves but then nothing happens and after a...
I have had the same problem with 3 Sony VPL-EX1s and Sony will not answer emails regarding the problem. Hence I wont be purchasing Sony projectors again.
Apr 01, 2009 | Sony VPL-EX1 Multimedia Projector
Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
Jun 30, 2008 | Sony VPL CS5 Multimedia Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
Green hue on screen
Hi there
If this shows on the image without a signal ( PC or Video ) then it could be one of your LCD's that need replacement
Feb 06, 2008 | Sony VPL-EX1 Multimedia Projector
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
Sony VPL-EX1 Multimedia Projector Logo
493 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
