If you know pincode then it iTry Master Reset Code here possible otherwise you have to install its software for unlock.
Try Master Reset Code here http://www.unlocking4u.com/unlocking-services/rs6wp6/ For Your Model Mobile in the list.
OR:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
or:
Contact your service provider to get a master reset code at free of cost.
would really apreciate your help...sony ericsson w200a ...imei# 35156602-963876-9-18.... country: MEXICO....network: TELCEL.... my e-mail is: [email protected] thankyou for your time
My Sony Ericsson imei no -35544101-401612-2-18 ..... please help me..... my phone is locked
35970701-388274-8-17
SOURCE: unlock sony ericsson w200i
switch it on and off very quickly ten times approx with a blocked simcard and then it should work. it happened with me
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the network that the phone is locked on, and the country you’re in. Then I will give you the codes.
SOURCE: How to connecting Sony Ericsson W200i
dear,
here is your pc suite.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/w200i
regards,
dont forget to rate it
SOURCE: method to unlock country code of sony ericsson w200i
please
.... my sony ericsson mobile phone is locked, the first koda I use is
1580, but the current mobile phone can not open .... please solution
imei number : 35379602-570215-6
DPY 101 3128/19
FCC id : PYA102204A
