I cleaned my cooktop by taking it all apart and cleaning each piece. When I put it back together the spark that ignites each burner doesn't work. I can hear it sparking on the wrong burner when I turn the knob on. Ex....when I turn the front burner on the back two burners are sparking. Only one burner is working of the 5. I have a GE Profile JGP636
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Hi If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like.If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram. Please do accept the solution if the issue is resolved or else revert for further assistance. Thanks Rylee
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
