SOURCE: Cannot Download pictures from camera to computer
I tried different card and it worked. I'm waiting to contact SanDisk to solve the problem. Hate to lose all the pictures. Thanks for your help.
SOURCE: camera will not connect with computer to download
If you got the Cable and Software CD, you can try to Uninstall the Software and then Install it again, as it may be some software/Dirver fault.
Regards,
Waqar.
SOURCE: I have a Canon EOS
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Canon ZoomBrowser or Picasa ( http://picasa.google.com ).
SOURCE: My canon rebel xt digital
If you haven't got this working yet let me offer a few suggestions.
It may be that the computer you are using has gone through an auto update or you have changed software. The Rebel XT is old enough that the camera firmware may not be compatible to the updated computer software. You may be able to update the camera firmware by going to the Canon site and download the updates they are free.
Or you can step around the camera by using a Memory Card reader. The reader is plugged into a USB port and the computer looks at it as an external Hard Drive or Mass Storage device.
You picture files can be downloaded to the computer Hard Drive and then the memory card needs to be "ejected" don't just pull it out the computer doesn't like it.
Once the memory card is placed back in the camera the memory card needs to be formatted and you are good to go again.
SOURCE: Why is my Cannon Power
Probably the image stabilization going out and just needs that part of the camera replaced. Try this site: www.camerasandparts.com They just service the Canon Powershots exclusively and they do terrific work on these cameras. If you need to have it serviced, they're the place. It runs $79 for parts, labor and shipping back with their flat-rate service packages. They're about half of what Canon wants and they do excellent work on these models. Good luck with it, that's a great camera that is known to take very good pictures.
Click the Windows "Start" button and click "Run." Type "msconfig" (without quotes) and press "Enter" to open the System Configuration Utility window.
Click the "Startup" tab. Scroll through and click "dwtrig20.exe" and click "OK." Restart your computer. The program will be removed from startup and will no longer run.
