You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Great Question, but it looks like it shouldn't be in the Cell Phones category! All questions need 'make model (what it is)' please and the correct category. We have them for all the Xerox machines
We provide support to the greater California area.
Please contact your support provider for this issue.
If you do not have one you can contact us at 858 573 6300.
This is a problem dealing with the fixing assembly and the thermistors not reading the coorect temp in a specific amount of time. The only thing that can be done is to replace the fixing film assembly and is best done by a qualified service man. These fixing assemblies have to be taken completely apart to replace the film and maybe even the pressure roller and heat sink. Good Luck.
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
Error u1-1 Xerox Docucolor 4 LP
"Error u1-1 Power Cycle"
When start print Mechine Goes to restart
Xerox workcenter Pro 428 error u1
