Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
