These units have a variety of places they can leak from ...unfortunately you will have to gain access..the most common area for leaks in this model is down at the botoom around the drain pump area and or hoses..they spin so fast that all kinds of items can go thrrough the system a pierce the hoses or shatter the pump assembly... gain access to the bottom of unit and run a small load cycle and watch it you should be able to locate the problem and buy your replacement part on line .. good luck hope this helps....
