ATTACHEMENTS ON HOW TO TEST MOTOR
The following test must be made on one-, two-, and three-speed drive motors:
1.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
2.touch the other ohmmeter probe to the terminal on the white wire from the motor.
3.The ohmmeter should show
ZEROresistance (continuity). If not, the drive motor is bad and needs replacing.
Start Winding
4.Touch and hold one ohmmeter probe to the terminal on the black wire from the motor.
5.Touch the other ohmmeter probe to the terminal on the yellow wire from the motor.
6.The ohmmeter should show a reading between 4-10 ohms.
7.If you do not get this reading, the drive motor is bad and needs replacing.
High Winding
8.Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
9.touch the other ohmmeter probe to the terminal on the blue wire from the motor.
10.The ohmmeter should show a reading between 0-4 ohms.
11.If you do not get this reading, the drive motor is bad and needs replacing.
12.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
13.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
14.The ohmmeter should show a reading between 1-5 ohms.
15.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on two-speed drive motors, along with steps 1-15:
Low Winding
16.touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
17.Touch the other ohmmeter probe to the terminal on the white wire from the motor.
18.The ohmmeter should show a reading between 1-7 ohms.
19.If you do not get this reading, the drive motor is bad and needs replacing.
20.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
21.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
22.The ohmmeter should show a reading between 1-7 ohms.
23.If you do not get this reading, the drive motor is bad and needs replacing.
24.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
25.Touch the other ohmmeter probe to the terminal on the white/black wire from the motor.
26.The ohmmeter should show a reading between 1-7 ohms.
27.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on three-speed drive motors, along with steps 1-27:
Ex-Low Winding
28.Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
29. Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
30.The ohmmeter should show a reading between 1-5 ohms.
31.If you do not get this reading, the drive motor is bad and needs replacing.
32.Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
33.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
34.The ohmmeter should show a reading between 1-5 ohms.
35.If you do not get this reading, the drive motor is bad and needs replacing.
36.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
37.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
38.The ohmmeter should show a reading between 1-5 ohms.
39.If you do not get this reading, the drive motor is bad and needs replacing.
40.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
41.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
42.The ohmmeter should show a reading between 1-5 ohms.
43.If you do not get this reading, the drive motor is bad and needs replacing.
44.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
45.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
46.The ohmmeter should show a reading between 1-5 ohms.
47.If you do not get this reading, the drive motor is bad and needs replacing.
48.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
49.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
50.The ohmmeter should show a reading between 1-5 ohms.
51.If you do not get this reading, the drive motor is bad and needs replacing.
52.Touch and hold one ohmmeter probe to the terminal on the white/orange wire from the motor.
53.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
54.The ohmmeter should show a reading between 2-8 ohms.
55.If you do not get this reading, the drive motor is bad and needs replacing.
The following three (3) checks must be made on all one-, two-, and three-speed drive motors to check for an internal failure (short):
56.Touch and hold one ohmmeter probe to the drive motor housing.
57.One at a time touch the other ohmmeter probe to each of the wires (terminals)coming from the drive motor.
58.The ohmmeter should show an open circuit when each of the wires (terminals)are checked. If not, the drive motor is bad and needs replacing.
HOW TO live TEST a G.E - MOTOR
After removing the cabinet follow the wires from the motor halfway up the tub. Then cut and splice the ORANGE, the BLUE, the VIOLET /WHITE, & the RED wires.
Now using a long long extension cord with the end connector cut off and exposing the 2 end wires stripped back about an inch.
To check the spin cycle: Connect and splice the RED & the Blue wires to one end of the extension cord wire. And the ORANGE & WHITE /VIOLET to the other end of extension cord, be sure to use but connectors or electrical tape. Plug in the cord an the wash cycle should start? If not the motor is bad.
To check the wash cycle: Connect the BLUE and the WHITE/VIOLET wires to one end of cord. And the ORANGE & RED connected to the other end of cord, then plug in and the wash cycle should start? If not the motor is bad.
By the way my advice is free cuz God is good!
