Will a jandy 2 speed pump relay work fine on an easy touch system? I know that I need a 2 speed pump and I can get thru the setting on the easy touch, just want to make sure that I can use a Jandy relay. Thanks.
Probably go for the 2 speed, manufacturers often embellish on the hp ratings of pumps, you will definitely see more energy savings from a 2 speed. Just stay away from hayward, easy to work on for service tech's for break alot. Go with Pentair or Jandy they are worth the money.
The Jandy Aqua Pure, PDA, or One Touch control system will absolutely turn the pump on and off . Brand and type are not relevant to the controller. Each "Relay" allows or restricts power to whatever device is connected to it. Find the relay the pump is connected to. Move the wires to a different relay (aux1, aux2) and try again. If the power is correctly hooked to the relay, it must work or there is a problem with the relay itself (possible). Rob
