SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
SOURCE: I need a user manual
There is a link to them on the Braun website. Here's a link to the English version:
http://www.service.braun.com/line/HH/H3045/H3045_2_NA.pdf
SOURCE: Blade Change Braun KSM2 Coffee Grinder
There is a small slot on the bottom for a flat screwdriver to lock the shaft in place. Then unscrew the blade.
SOURCE: I cannot find a user manual for my Braun 4045
I dug in and found your manual at Braun. Take this link and select the second choice to print your 9 page manual. Let me know if further assistance is needed.
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=s&sgrp=s&grp=HH01%3C%7C%3E&s=kmm30&subgrp=0
SOURCE: Part for Braun 4045 coffee grinder
depends if ur DIY (do it yourself)type or u know someone who are..or last solution is to order from factory..
