SOURCE: connecting to the onboard speakers on the flatron 776fm monitor
You simply need a miniature stereo audio cable. Radio Shack carries them.
srich
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
SOURCE: LG Flatron 776FM mic is not working
it is the one that is blue in color and has an L on it for low pressure. The vapor line is also called the suction line. If your confused, then choose the larger of the two lines near the accumulator.
SOURCE: I want to remove the rear cover of the lg flatron
simcraft's link was great ! It has pictures showing the dismantling procedure, but the document is in Chinese and so is the web site where it is located. Please remember that some internal components can retain a dangerous charge of electricity for a few minutes after disconnection from the ac outlet. Wait at least 5 minutes before attempting the disassembly. Try to find the service manual for any other LG LCD in your language and read the safety procedures - they are pretty much the same for all models.
SOURCE: How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
