Master
- Posted on Jan 02, 2011
Re: I have a Maytag front load washer. The washer will...
If you have a wet dry shop vac you can use it. Connect it to the end of the drain hose and remove the water that way and the door should unlock.
Once the water is gone you will need to check the drain pump and hoses for anykind of obstructions.
