SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit. The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: The light is not on in the microwave when I open the door
Depending on the model, you might NOT be able to replace the bulb yourself.
With many microwave appliances the bulbs are located in a secure area away from the cooking area of the machine. If you look inside the oven, you should see an area that looks like a grill of sorts. This is most likely where the bulb is located and might not be readily accessible for you to replace unlike a conventional oven light bulb is.
Verify first where the bulb is located. If it is located in an enclosed area of the oven, you might need to call for onsite service from Whirlpool to replace the bulb. Most likely this is the case. And you should ask yourself:
1- Is the unit in warranty still?
2- If YES, then call Whirlpool Service to have it worked on
3- If NO, then ask yourself, how much do I really need a light, because to have someone come out and service the unit will cost about $100+ USD to get it working again.
I know this is not what you wanted to read as a solution, but it might be the only thing to do. There is no listed part number for a replacement bulb therefore, it is a service installable part only.
Hope this helps you out.
Cheers,
Keith
SOURCE: Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
We're
happy to help you with free advice and we'd appreciate your
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
