Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
A
Anonymous Posted on Jan 01, 2011
WHO MANUFACTURES THE ENGINE FOR THE BUFFALO TOOLS GENERATOR EX: 4000 W OR 10000 W SIMPLY PUT WHAT KIND OF ENGINE IS ON ANY OF THEM
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1464
Points
5
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
2answers
I need a wiring diagram for a buffalo tools 7,000 kw propane generator - any idea where to get one?
try googling buffalo tools 7,000 w propane generator manual
7000 kw is a very large unit - 7,000,000 watts
2answers
I need valve clearance for Sportsman 7000 generator 18hp please
Edited for clarity and moved from Cars to Generators.
Valve clearance goes by the engine, not by the generator maker. They are usually Briggs and Stratton, Honda or Kawasaki.
https://www.google.com/search?q=Sportsman+7000+generator+valve+clearance
2helpful
2answers
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Recoil broken
find out who manufactured the engine... if it's a honda knock off a honda recoil might work and you can get an after market one for cheap... like $30 USD or something close
Do you have a manual for a buffalo tools 2000 watt portable generator?
HOPE THIS LINK WORKS.
http://www.buffalotools.com/manuals/gen154manual.pdf
it is the Gen you got, I have same.. Condenser failed after 7 yrs. Just suddenly stopped putting out. Kept running nicely though!
1helpful
What sparkplug is for the Sportsman GEN7000LP Propane Generator?
Take the plug out and go to Home Depot. Buffalo Tools makes that unit and Home Depot is a seller
1helpful
2answers
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Top Buffalo Tools Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
