This is usually a sign of your Internet service having a problem.
Do you see any indication on the modem of a problem? Have you tried connecting a computer directly to the modem to see whether you see the same slow response?This is usually a sign of your Internet service having a problem.
You can't post conmments that contain an email address.
Do you have a battery backup/surge protector?? Take it out of the loop and plug directly into the wall.
From DELL
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist. Ensure that the voltage selection switch is set to match the AC power at your location (if applicable). Ensure that the processor power cable is securely connected to the system board
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Pull out the battery and replace it again. Then power it on again. If the problem persists, you will need to have the motherboard, processor and RAM checked by appropriate technical personnel. Any of these could be responsible.
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Your responses are intended to improve the level of service provided. Please rate your experience. Thank You.
