Siemens SpeedStream Modem (4100) (SS4100) Logo
Posted on Dec 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I configure for wireless? - Siemens SpeedStream Modem (4100) (SS4100)
Anonymous
Level 2:
New Friend:
  • Expert 84 Answers
  • Posted on Dec 31, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
84
Questions
0
Helped
18699
Points
292
Siemens Speedstream 4100 is just a modem, if you want to connect to the internet wireless you will need to set up your speedstream modem with a wireless router.
It can work with almost all the wireless routers available in the market, but I would recommend a Linksys wireless router.
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 • Computers & Internet
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
1helpful
2answers
My computer died we redid widows xp disk and it came back now i dont have wireless how do i get it back
Hi, you will need to reinstall the wireless card drivers, if this came with wireless as standard you should be able to download the drivers from the manufacturers support website, if it was added later on then it should have came with an install disc with the drivers on it.
Hope this helps
John
1helpful
Cannot get on the internet because of article 871122
This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then click Change settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then clickOK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
How to set wirless network by router
First configure the wireless router with the SSID and WPA encryption etc and the configure the wireless card in the computer with the wireless router's settings. Please click on this link for information on how to secure the wireless router, configure the router's wireless settings and configure the wireless card in the computer with the router's wireless settings :-
http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
1helpful
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
It says i am connected to wi fi internet but cannot browse it says see article 871122 microsoft knowledge base on microsoft.com please help do i need to download something.
1.) Pls. use the software for your wi fi adapter, connected on desktop to connect to the wireless lan.
2.) microsoft: This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
