How to install E63 themes?
There are three ways that you can install your Nokia themes on your
phone. One is through over the air downloads, in which case, you just go
directly to the site with your chosen theme, click on the link, and
follow the instructions on your phone.
If you're downloading the
themes on your PC, there are two ways you can install it on your mobile
phone. One is through the Nokia PC suite, and the other is through
Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite:
1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start.
2. Click on the "Install Applications"
3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window.
4. Select your chosen theme and then press the arrow in the middle of the window
5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions)
1. Data transfer.
Connect your phone via USB cable and select "data transfer" on the mode
menu. When you connect your phone and it shows up as a removable disk,
transfer the theme on your phone's storage card. You can install the
theme by using the file manager and selecting the theme to install. 2. Bluetooth.
If your friend has a theme on their phone, you can have them transfer
it on your phone via Bluetooth transfer. The theme will appear on your
messages and to install it, simply click on the transferred file on your
messages and follow the prompts.
hope this helps...
