Bosch model HBN 222 BAU oven not heating to correct temp.
top element works in grill mode.
When oven switched to bake (either fan forced or convection), top element
doesn't feel hot, can feel bottom element working and fan is working ok.
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
this did not help me at all
grill top oven element
Which part # fan forced oven element would fit a Baumatic BA2850 dual cooking theatre?
belling b170 g top oven switch faulty when grill is slected the fan does not come on and th grill does not heat up
My Neff Mega 4569 oven has stopped getting above about 80 degrees. The bottom & top grills are working, the fan is working, as is the light but the oven will not get hot - please help!!
I can't get the grill to operate. The top oven works ok
element gets real hot even on low temp,cant control temperturein oven
fan force is not working nor is the back element
We have an electric & gas Baumatic range oven. The smaller electric oven works fine. The larger oven does not. Neither the top nor the bottom element will heat up and the rear fan does not spin. The internal extraction fan, presumably on a different circuit, does work,
bottom oven not getting hot but the grill works ok replaced the element
i have a lamona oven but no user guide so i dont know what the settings means.when i put the oven on with the sign which looks like a straight line top and bottom with a fan in the middle,the grill comes on aswell.is this right
hi on hot air setting oven does not get to required temp stays cool works on grill and upper/lower heater setting
