2002 Jaguar X-Type Logo
Posted on Dec 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
ZJ Limited
Level 3:
  • Jaguar Master 17,989 Answers
  • Posted on Dec 31, 2010
ZJ Limited
Jaguar Master
Level 3:
Answers
17989
Questions
0
Helped
14458491
Points
60858
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
I replaced the front passenger accuator.which works fine.the door unlocks and locks with the remote.when i shut the door it wont open.you can feel the cable pulling slightly but not enough to disengag
Hey Trent once ya gain access to it again go where the metal tab is that holds the cable in place and simply give it a little tweak with a pair of pliers pulling it so it stretches the cable slightly and then test it and im sure ya know now but never put the panel on till ya test it.
good luck n hope this helps. Geo
I replaced the power lock switch on the driver side of my chevy malibu because the locks were locking and unlocking by themselves, I also heard a beep under the dash. The problem was taken care of. Now...
All the lock's ,were locking an unlocking or just the driver door lock ? Probably wasn't the switch ,more likely a bad input to the BCM . The door lock's are computer controlled .
Do you know what a BCM is ? body control module .
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
1998 Dodge ram van 3500 door will not open. power locks that cick on for open & close don't work
Not easy to find, incorporated in the lock itself, usually a little tag sticking out to pull/push, but it is normally on the side you can't get too, I take the lock out complete and then you know what you are working with, you can see how it all works that way!!
2answers
Toyota Celica 2000 GTS hatch won't unlock
Go inside the rear hatch area remove the trim panel and manually trip the hatch release.
1helpful
2002 Suburban 1500. Driver's side power door lock, the actuator does not move the rod to lock or unlock - must do it manually. The rest of the power locks are working, and I can hear the actuator in the...
I have struck silimar issues with fords in NZ. If the actuator is getting full voltage during lock and unlocking, the actuator is faulty. Even though it wants to go it does not have enough strength to pull the lock mechanism, so it can not lock or unlock the catch.
2helpful
2answers
Sunburn 1994 handle wont work
Yes, Usually If you pull inside the lock area incorrectly, it will cause the rod to detach from the door latch. The door panel will have to come off and the rod, located and reattached. The retaining clip probably is damaged so inspect it and you should be able to find a replacement at NAPA or local dealership.
2003 ford windstar - power locks only open drivers door
yes it is the door lock switch in the door trim panel it should pop out from the back to forward / Please rate my response thank you very much
Door panel removal
  There is hidden screw under top of arm rest.  the mirror control comes out.  Be careful.  then there are 2 screws in bottom of arm rest.  Then the arm rest/handle needs to spin up towards sky and it will pull out.  the scushing (plastic around handle ) slides forward and this handle surround will come off.  Then there are clips that are behind panel.  Put hand between door and door panel and pull panel outward. be careful.  sometimes firm tug is better
2answers
PT CRUISER
look for the edges around the radio get a thin putty knife seperate the panel from the rest it should just pop out/ as you put the putty knife you will know where the push in retainers are again just pull out/ Please rate my response Thank you very much
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
