Hi this is Shaik, I just changed my XP style and then return to my home XP style, but now i cannot able to shutdown my PC, it shows RCINT failure string ID table not found. Plz help me to solve this problem
let me tell what will i do if i m at your place.. i will prepare a windows 7 bootable pendrive first.. then i will forcefully shutdown windows.. then i would turn on pc & i will boot from pendrive and perform a clean install .. i will also format whole harddrive so that problem is uprooted.. try this
Something you have running in the background is failing. Googling around shows one person who had installed Style XP and that was causing the problem. Other links show people having the problem but no solution. So if you haven't installed Style XP, you'll need to do some systematic troubleshooting.
The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't?
The Second Question of Windows Troubleshooting: what is the malware/virus status of the machine? If you think it is clean, what programs (and versions) did you use to determine this?
If the computer is completely virus/malware-free, manage your startup to find the culprit.
Start>Run>msconfig [enter]
This brings up the System Configuration Utility. Look on the Startup tab and find the probable culprit. Uncheck the box next to its name, Apply and OK out. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Just tick the box that says in effect, "don't bother me about this again".
Try running system file checker. It scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Start, Run, "SFC /scannow"
The error you're referring to is most often caused by pieces of software, such as LogonStudio, replacing system files.
Whenever u disable the windows welcome screen setting in xp the shutdown menu will be different. Goto Control Panel-> User Accounts -> Change The User Logs on and then check the Use Welcome Screen. You`ll get back ur old shutdown menu
