Question about HP cp1700 Color Inkjet Printer
Can I configure an on-screen monitor since my display in not working on my hp cp1700
    New Friend:
If you install the HP Color Inkjet CP1700 Toolbox software it will give you all the on screen monitoring you need in lieu of a defective LDC display.
Posted on Feb 14, 2011
Anonymous
SOURCE:
HP Color Inkjet cp1700 Printer Driver Download
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-inkjet-cp1700-driver-download/
Thanks
Apr 08, 2013 | HP InkJet Office Equipment & Supplies
Sir my hp 19 inches monitor is often getting flickering while doing my work plz give a suggetion to reslve it
Sir I will be very happy to assist you with your problem . 1. First right click any where on the desktop and click on properties which will open the "Display dialog box" from which you can change the display settings.
2 . Click on settings tab and then "Advance" button ,This will open the "Advanced Settings" dialog, which allows the user to configure advanced display settings
3 . Click on monitor tab which allows the user to configure the monitor's advanced settings.
4 . Navigate to the "Screen Refresh Rate" drop down box under "Monitor Settings" and choose a higher refresh rate.
Now you are done .
Thanks.
Oct 17, 2010 | Computers & Internet
Line under the screen. cannot be removed from sytem configuration of laptop, video card and windows setup.
Some monitors and laptop displays have a protectice strip between the plastic frame and the screen. After awhile these strip begins to move and it works its way down onto your display. You may want to contact your Manufacturer if the laptop or Monitor is under warranty
Apr 18, 2010 | HP Computers & Internet
Display does not light up
This is problem many of hp cp1700 printers. LCD display have manufacter issuse. After some time degrage material joins LCD with controler. You can partial fix this issue, but you must take to parts front panel and repair cable contact on both side of plastic flat wire
(one side plastic flat wire and LCD, two side plastic flat and LCD controler board ). Repair must be done with stress dull tip and hot temperature, may use tinfioil and soldering iron.
OR you can bay new part panel board with lcd aproximaly 150$.
OR you do not repair printer and use pc program that view display info form printer display on pc monitor. On Linux I use HPLIP Toolbox.
Dec 03, 2009 | HP cp1700 Color Inkjet Printer
Display on HP cp1700 has faded
Its the cable which attaches to the lcd display, you have to press on the contact areas where the cable attaches to the lcd glass and circuit board.
Sep 02, 2009 | HP cp1700 Color Inkjet Printer
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
HP Inkjet CP 1700 Inop
The digital readout on the CP1700 is a problem. I have replaced mine now 4 times at a cost of $90 each time, and I'm going to have to do it again or get the new 2800. Just wonder if the 2800 is going to have the same defect.
Jul 14, 2008 | HP cp1700 Color Inkjet Printer
Presario v2000 notebook problem
Put another monitor and go to the display settings settings advanced and there u can configure display settings if it wont work so just change the monitor
Oct 20, 2007 | HP Compaq Presario V2000 Notebook
HP cp1700 printer display panel blurred
is it the print coming out ok or blorred go to hp website and download drivers and software plus contact them for assistance on your printer. hope this has helped
Aug 14, 2007 | HP cp1700 Color Inkjet Printer
HP cp1700 Color Inkjet Printer Logo
187 people viewed this question
Ekse
Thomas F. Schneider
