SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
SOURCE: I have a pentair intelliflo
Check the wiring connections, and count how many times the alarm light blinks upon start up. It is probably a loose or broken connection, but the alarm blinks will give us more information to go on if its not.
I install these regularly for 3 years and the only time I saw this incident was when I had a bad connection inside the J-box.
SOURCE: I have a 1-1/2HP pentair pool pump. When I try to
Thank you for posting your question here on Fixya.com. If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although It is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
John
SOURCE: My Pentair WFDS-28 pump wont
Since it is not bound up it is likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
John
SOURCE: I have a Pentair Superflo 1.5 HP pump and I called
Bearings squeal before they sound like gravel spinning in the motor; they are most likely what is causing the noise and they need to be replaced.
John
