Belkin (F5D7132) 802.11b/g Wireless Access Point Logo
Posted on Jul 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belikin adapters and a wireless gateway
Hello Support,
I already have a router. I need to have my desktop computers wirelessly connection to the existing router. I see that I can order Belikin wireless adapters. Can you tell me which wireless gateway (not router) I can use to point the Belkin wireless adapters to?
Thanks,
Anonymous
Level 2:
  • Expert 57 Answers
  • Posted on Jul 10, 2009
Anonymous
Expert
Level 2:
Answers
57
Questions
0
Helped
21167
Points
118
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
2answers
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
1helpful
2answers
Im trying to hook up wireless internet is there a wireless switch or do I need a wireless card?
hello
you have two ways to go about this , USB wireless card or USB adapter
go to this link to get an idea
http://www.discountelectronics.com/index.php?l=product_list&c=7160
please send me 4 thumbs up
I want to put usb wireless adapter on my old gateway Ess 500 computer so my 5yr old grandson can play his online games what kind of adapter should I buy
The friendly user that I recommend is Belkin wireless adapter ( assuming you got wireless modem)> If you don't have wireless modem you'll need to buy wireless router as well to be install in your main computer
Hi. I am using a wireless adapter with a desktop computer. This computer connects to a wireless router but the internet acces is through a laptop in this network that uses a mobile internet solution and...
It appears the wireless adapter is not working properly or is not configured with the wireless router's settings Ie. the SSID, and encryption etc.
First install the latest wireless adapter driver.
Next configure the wireless adapter with the wireless router's settings.
It needs to be the same as the wireless settings in the laptops.
If you need further help, please contact me.
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
3helpful
2answers
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Desktop wireless internet problems
The same happened to me, I just unplugged the router and plug it again, and i got internet access.
2answers
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
