Here is the link ( http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915PGN) or click here
you have 3 coloum
in 2nd coloum
Select an Operating System( select accoding to your pc)3nd coloum
CLok on Drivers
you will get list of drivers below so that you can easily able to download all your drivers.
Good luck
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
SOURCE: my asus p5gc-mx motherboard sound driver cd is missing
Killer rig :-) Do you have it connected Raid 0? Yes, here ya go:
http://support.asus.com/download/download.aspx?SLanguage=en-us
This is for XP. If XP is not your OS, then select your OS.
SOURCE: how can i get the driver MSI 945GM2 (LGA775 Intel Pentium 4)
Here what you requested
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=225
SOURCE: i have a D102GGC2 motherboard
Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
Manufacturer:
Intel
Part Number:
BOXD102GGC2
General
Product Type
Motherboard
Form Factor
Micro ATX
Width
9.8 in
Depth
8.6 in
Compatible Processors
Celeron D ,
Pentium 4 ,
Pentium D
Processor Socket
LGA775 Socket
Multi-Core Support
Dual-Core
Chipset Type
ATI Radeon Xpress 200 / AMD IXP 450
Max Bus Speed
800 MHz
Storage Controller
ATA-133,
Serial ATA-150
Power Connectors
4-pin ATX12V connector,
24-pin main power connector
Processor
Installed Qty (Max Supported)
0 ( 1 )
Memory
Supported RAM Technology
DDR2 SDRAM
RAM Installed ( Max )
0 MB / 2 GB (max)
Supported RAM Speed
PC2-3200,
PC2-4300
RAM Features
Dual channel memory architecture
Video
Graphics Controller
ATI Radeon X300 Shared video memory (UMA)
Audio
Audio Output
Sound card
Audio Codec
Realtek ALC861
Compliant Standards
High Definition Audio
Telecom / Networking
Networking
Network adapter - Realtek RTL8101L - Ethernet,
- Fast Ethernet
Features
BIOS Features
ACPI support,
SMBIOS support,
Rapid BIOS boot
Hardware Monitoring
System voltage,
CPU fan tachometer,
Chassis fan tachometer
Sleep / Wake Up
Mouse wake up,
Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Wake on PCI device,
Suspend to RAM (STR)
Expansion / Connectivity
Expansion Slots Total (Free)
1 Processor - LGA775 Socket,
2 Memory ( 1.8 V ) - DIMM 240-pin,
1 PCI Express x16,
1 PCI Express x1,
2 PCI
Storage Interfaces
Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
Interfaces
4 x Hi-Speed USB - 4 pin USB Type A,
1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
1 x Storage - Floppy interface - 34 pin IDC,
1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
Hope this helps.
