Question about Motorola AP300:802.11A/G, Internal Antenna (WSAP-5110-100-WWR) 802.11a/b/g Wireless Access Point
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
  • 573 Answers
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Posted on Dec 30, 2010
    New Friend:
  • 7 Answers
It may not be adopted on the wireless switch, check you config on your WS /RFS unit, another option is that the AP300 can not see the wireless switch, do you have VLAN's on your network, is the AP in the correct VLAN ?
Posted on Apr 04, 2014
    New Friend:
  • 3 Answers
My motorola gp 300 keep flashing light when turned off what could be the cause
Posted on Mar 31, 2014
  • PHIL
    PHIL Apr 22, 2014
    What do you mean ? The Wireless switch is turned off ?
  • PHIL
    PHIL Apr 22, 2014
    The AP is 802.11AF compliant, so the AP is either powered from an ES3000 or from a local PoE ( power over Ethernet ) supply, the exception to this is the WS2000 or the RFS6000 which can supply power from the switch itself, If you mean when when you power off your laptop / device the AP will still flash as it picks up the heartbeat from the WS and all so some network traffic
6ya staff
SOURCE:
How do I fix my Dell computer that keeps blinking amber color light and does not turn on?
You are going to get a range of opinions on this one. Some suggest a new power supply and others more invasivel repairs involving removal of the front panel and soldering!
http://www.tomshardware.com/answers/id-2277673/dell-wont-boot-amber-blinking-light.html
Apr 21, 2015 | Dell OptiPlex Computers & Internet
How do i do a manual reset to my en genius EAP 300 Access point. ?
First, make sure the AP is turned on. Now, grab a pencil or something pointy and press the little button above the wrench on the top of the device. Keep it pressed down for about 10 seconds. Hopefully this will reset your AP.
Nov 02, 2013 | EnGenius EAP300 - wireless access point
Aironet 1100 ap amber led light
What controller are you using? You are correct - it is an IOS error. Usually the AP is not compatible with the WLC ios.
Mar 16, 2013 | Aironet 1100 802.11a/b/g AP...
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
How do you turn off the Vmatic amber light on a
Press both the reset and mode buttons at the same time. Turn on the ignition. Keep the buttons pressed for 5 seconds. Light will start blinking. Release the buttons and the light will go out.
Dec 12, 2009 | Honda Silverwing 600 Motorcycles
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Motorola AP300:802.11A/G, Internal Antenna (WSAP-5110-100-WWR) 802.11a/b/g Wireless Access Point Logo
3,072 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Peter Dragonetti
Ekse
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
