Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card Logo
Posted on Jul 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E-GeForece 6200 displays partial image when plays avi video
I just got one e-GeForece 6200 card and works fine with almost everything except playing avi video. It displays only central part of the video image, but other computers display the whole part of the image with the same file. rmvb files are fine. I tried with different players, they are all the same.
Do you know any of the solution? My system is XP.
Thanks,
Fang
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Jul 11, 2008
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
15479
Points
106
Hi im wesley. um a problem might be that the players you are using dont have the right plug ins or dont support the file try using vlc player it works with almost everything
Unable to play mkv, mp4 in vlc, Mpc or Potplayer. The video is just freeze or choppy. AVI and CPU reaches 100%. My system is Dell dimension 3000, Pentium 4, 2gb ram, nvidia 6200 pci video card and 250
Hi..
This is what happen to me also, but after i do some clean into my fan processor, fan graphic card, and do vacum inside my computer ( because has too much dust). Too much dust also can make your pc performance going bad.. settle about cpu performance.
Regarding you cant play mkv file and other video format. Did your computer has a software to make all video can run that we called codec code? Try to install it and play it. Maybe this software can help This is a link to download the codec code.
Codecs com Downloads for Lite Codec Pack 10 2 Full Standard and Basic
Thank and have a nice day..
2answers
My sharper image touch mp3 player won't play .avi files.
The problem is that the player of this MP3 has a corrupted program. If this device could play .avi and .mp4 before, you need to contact the manufacturer and have them reloaded the program.
But if you haven't tried playing .avi and .mp4 file format before, then refer to the user manual to verify it this device supports those video file format.
Thank you!
2answers
No output from Geforce 6200 AGP
check in your bios settings that the correct settings is enabled if its pci or agp, maybe its some thing like this. hope this helps. also remove your drivers before your take out the card to changed it with another card, by add remove programnmes in control panel.
1helpful
Video card geforce 6200 with 256vid on an Asus
Your computer needs a video-codec for it in order to play all the kinds of video and audio format. I will give this link to download the necessary codecs for your computer, hope this could help you. Good Luck..Thanks..
Just copy and paste this link into your internet browser.
http://www.free-codecs.com/download/K_lite_codec_pack.htm
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Video clips play upside down
Make sure you have a mpeg4 decoder loaded into your computer.
You could try another player too.  www.divx.com is a great mpeg4 media player to use and it is free.
Geforce 6200 Graphics Card
I dont think its your graphics card, its possible that its your computer thats not suitable for games all together.
Please follow these steps to ensure that your computer is capable of playing games.
Direct X Diagnostic
  1. Start > Run
  2. dxdiag
  3. click Ok
  4. Check System data. Key Points: Processor and Memory (RAM)
  5. Check Display. Key Points: Memory and Graphics Card type.
If all of this looks fine, then try and update your drivers for the Graphics Card.
1helpful
3answers
File won't play video
The reason that the video is not playing is because the video uses certain "codecs" to decode the video. (It is basically a way that the computer interprets how to display the video on your screen.)
You need to install a good codec pack so that you can play all formats of video and/or audio.
I recommend using K-Lite Mega Codec Pack. It plays everything from Windows Media (AVI) to Quicktime files and just about everything in between. This is a very widely-used and popular codec pack. It also comes with a much simpler version of Windows Media Player. (It shows as an older version...and even looks like an older version, but it is only based on the older version as it honestly worked much better than newer versions.)
Here is the link.
(Click HERE to download the codec pack.)
Just use the DEFAULT installation. Don't change anything. There is no need to. Once it is installed, it will use the version of Windows Media Player that I just mentioned by default.
But if you still wish to use version of Windows Media Player that you currently have installed, then you may feel free to do so. It will still play videos using the same codecs that were installed by K-Lite. (All A/V programs will use the codecs.)
Another player I have recently found is GomPlayer. Very nice interface. Clean and easy to use. Install K-Lite and try out GomPlayer if you like afterwards.
HERE is a link. According to the site, you may not have to install any other codec packs after installing GOMPlayer. That may or may not be true. It IS OK if you install both.
Good luck. Let me know how it goes. :)
Cyryl
2answers
Freeze with mpegs
Have you installed the latest direct X9 and have you completely uninstalled the last graphics card driver ad re-started your pc, if you had one previously as this can conflict. There must be a major driver problem as video's can be played on the most basic of graphics card. The only other problem may be the NVIDIA chip is not compatible with the motherboard, as i have had this in a number of cases before and had to replace with an ATI chip based card.
Top Evga Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
