Cars & Trucks Logo
Posted on Dec 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a belt diagram for the serpentine belt on a 2006 dodge ram 1500 hemi- can you help?
Sean Piquet
Level 3:
  • Dodge Master 1,867 Answers
  • Posted on Dec 29, 2010
Sean  Piquet
Dodge Master
Level 3:
Answers
1867
Questions
Helped
610047
Points
7259
You will find it in this Dayco PDF document. It is diagram 7.57 on page 124. The vehicle is listed on page 40 (2006 Dodge RAM pick ups) with the reference to the belt routing diagram. Copy and paste this web address into your web browser and away you go.
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1120b6e8f406fd3e862574c000569a91/$FILE/SerpentineBeltRoutingGuide.pdf
(If you have trouble with this then open this web page below and click on the serpentine belt routing guide PDF to open the PDF document...............
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1120b6e8f406fd3e862574c000569a91!OpenDocument
1 Related Answer
Dave Leoni
  • 66 Answers
  • Posted on Jun 03, 2009
SOURCE: Need diagram to install serpentine belt on 2004
There should be a diagram under the hood on the fan shroud or radiator support. If not, let me know and I see if I can find one. For the most part, if the pulleys it rides on are grooved, the belt ribs ride on it, it the pulley is smooth, the back side rides on it. From a picture of the alternator I have, from the passenger side coming up, over the alternator, then down and under the belt tensioner (smooth pulley), then up and over A/C compressor, then down and around P/S pump, up and around water pump, down around crankshaft pulley.
2answers
4.7 ram 1500 serpentine belt diagram
Here is the link to view the serpentine belt diagram for 4.7 Dodge Ram 1500: https://serpentinebelthq.com/2004-dodge-ram-1500-slt-4-7l-serpentine-belt-diagram/
2006 dodge ram 5.7 litre hemi serpentine belt diagram
A diagram should already be available inside the hood on the radiator support of the fan covering. If not, follow this link: https://skippingtheinbetween.blogspot.com/2017/03/30-2006-dodge-ram-1500-serpentine-belt.html. Basically, if the pulleys are grooved, the belt ribs ride on it, and if the pulley is smooth, the backside rides on it.
5helpful
3answers
Need belt routing diagram for 2005 dodge ram 1500 hemi 5.7
Accessory serpentine belt routing: Alternator (1), idler pulley (2), P/S pump (3), A/C compressor (4), crankshaft (5), belt tensioner (6) and water pump (7)-5.7L engine
2005 dodge ram 5.7 hemi serpentine belt diagram
A 2005 ram 1500 5.7 hemi
Why the engine turns off when the neg. Cable is detached from the batterie?
I already change alternator for a new one.
Need Serpentine belt diagram for HEMI 2004 truck ?
this diagram should be on the core support rail or on the hood if not contact a dealer they will have the info you need or a local library will gladly help you.
10helpful
I need a serpentine belt diagram for adodge
Here's your belt diagram.
if it's not correct let me know and I'll get you all the routing diagram for that year ram 1500.
Hope it helps.
45helpful
2answers
Need a diagram for fan belt or serpentine belt
Here is a diagram for a 5.7L Hemi, and 1 for a 5.9L diesel. Hope this helps!
9d0184e.jpg 5,7L HEMI
5.9L Diesel
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
