In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
