Question about Samsung SW62ASP Top Load Washer
Hi I have samsung top loader washing machine.Now i could here some water sound inside the washing machine when is shake the washing machine i.e below the tub..I just want to know what is the problem behind this and hw should i rectify this as only one year over i bought this machine...
    Problem Solver:
  • 15 Answers
The inner bowl has whats called a balance ring which means the top layer ring around bowl has water inside to keep washer balanced...this is perfectly normal
Posted on Feb 22, 2011
  • Mahmood Ali Apr 15, 2011
    markcaulfiel, thanks for the info.
    I disassembled my washing machine to clean it and when I removed this tube which is located on the top of the bowl I heard this sound and I suspected that it was for balancing but I wasn't quit sure about it. maybe it is leakage and needs to get this water out. I googled it and lucky to find your post to confirm that it is for balancing. thanks dear
6ya staff
SOURCE:
What is the Aqua Preserve button for? It does nothing when pressed during a wash cycle.
Rinse once for this to work::::;;;Hi it reduces waste of water by reusing last rinsed out water ...won't function when u select rinsing twice ..cheers
Jul 15, 2017 | Samsung Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
My samsung top loader washing machine has black rubber like stuff when washing. How can I remove this stuff?
Hi all of them does it that is the staysoft having a reaction.only thing to do is to full it with water and remove the drian plug at bottom of machine to remove it.hope this helps
Mar 21, 2011 | Samsung SW62ASP Top Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
The washer shakes violently and crawls forward - so far forward as to unplug itself. Help !
Sounds like a broken damper.
The drum assembly inside a front loader is noramlly supported by two or more big springs on the top, and two damper units underneath. If either or both of the damper units fail, the machine will still work but when spinning, the drum assembly will be able to move excessively causing serious vibartion - as you describe, quite often the whole machine leaps about !
If your comfortable working on washing machines, and can get hold of spares for your machine, then it isnt too bad a job. Otherwise, call an engineer !
Sep 22, 2009 | Samsung WF337AA Front Load Washer
Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Aug 13, 2008 | Washing Machines
Samsung SW62ASP Top Load Washer Logo
1,184 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
