One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
This is battery
related. On top of your unit is a battery pack with three colored led
lights. You can tell what is going on by looking at these. This
information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates
the batteries are fully charged. A flashing LED indicates the
batteries are being charged. NOTE: Batteries do not have to be fully
charged to operate the motor unit. YELLOW LED: The motor unit has
lost power and is operating off of the BBU. A solid LED with beep,
sounding approximately every 2 seconds, indicates the motor unit is
activating the door and is operating off of the BBU. A flashing LED
with beep, sounding every 30 seconds, indicates batteries are low.
Once the power is restored the BBU will recharge. This is indicated
by a flashing GREEN LED. RED LED: An error has been detected and the
BBU will automatically shut off. The BBU will attempt to restart by
reconnecting to the batteries. If the error is still present it will
shut itself off again. This process will repeat every 5 minutes or
until the error has been resolved. This is used to prevent further
draining of the batteries. If a red LED remains on when the power is
restored, and is accompanied by a beep sounding every 30 seconds,
please call for service.
This is battery
by a flashing green LED. RED LED: An error has been detected and the
This is battery
This is battery
This is battery
