Sharp 32F540 32" TV Logo
Posted on Jul 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Switching Channels Automatially
How do I replace the tac switches
Anonymous
Level 2:
  • Expert 129 Answers
  • Posted on Aug 16, 2008
Anonymous
Expert
Level 2:
Answers
129
Questions
Helped
43161
Points
171
Good day.
You need to pull out the board from the unit for you to replace the tac switches.
Regards,
chris
Vizio LCD 47" switching channels takes very long
Has it always done this since you purchased it? Check the response time online for that TV, it may just be that it is a model with poor response time when changing channels. I've seen some value brand TVs that seem to take a full second or more to switch and go blue/black in between while switching.
Very painful to channel surf like that, so if you have a cable box etc hooked up use that for surfing channels instead if you can't handle the wait.
My channels on my tv keep changing on its own everytime i turn on the tv. i tried new outlet, new batteries, and turned on manually. and left it sit for a week. but the channels keep changing on there own...
defective tac switch on the manual channel button, it is found inside under the button, this causes the program to change channel because the connection of the switch is shorted..normally it should be N.O. (normally open)...try to replace a new tac switch..
2answers
Tv turns off when changing channels no problem if tv is left always on?
Is this when using the remote? if yes, the remote is the problem.
N Sabre
3helpful
I have no front control panel working and changes channels
The front controls are called Tac Switches. They have a tendency of becoming corroded and sending erroneous commands to the micro. You can disconnect the lead coming from the control panel to the chassis and see if it quits. If it does, that answers your question. If you decide to replace them all, try Encompassparts.com
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Sharp 32f540 switching input channels
Ladythree,
the problem for your unit is the manual button switches. In the long time it wasnt used. it got stucked and somewhat rusted. This problem can best be addressed by replacing the buttons switches(tac switch).
this should solve your problem.
chris
3answers
RCA 36" TV Model F36645YX2 - Scrolls Through All Channels
if you have a soldering iron you can try to desolder the program+ and program- tac switches switch on the tv again and see if it still scrolls if it doesnt scroll through the channels it means that one of the switches is faulty your remote should work once you desoldered the tac switches replace the tac switch
Volume control problem
The MX50X1 uses a series of tac switches for ch+/- vol+/- and power. It would be my first suspect. The vol- tac switch may have become thermal or what we in the industry refer to as the windex syndrome. We see this a lot on direct view TVs usually because the switching board is directly below the screen and every time someone cleans the screen with windex an trace amount of the fluid might drip all the way down to the board and invade one or more of the tac switches. This isn't the only reason a tac switch goes bad or becomes thermal sometimes it just simply fails... Tac switches are cheap (less than $2.00) but the labor to put them in is probably one shop hour. Find a good shop and have them do it - - If you're not sure where to find one goto: http://www.nesda.com/locator/state_search.php and start your research from there... Good Luck Bill PS: Impress the shop you call and tell them you think your TV has developed the windex syndrome. They'll probably think you know a lot more than you do about TV repair. :)
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
