SOURCE: Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
SOURCE: Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
