Is the V26 DLP PWB PCB kit easy to install, if your not a tech guy.
The hardest part is getting the chassis block out. But if youre mechanically inclined and follow the illustrations and label all the wires you unplug, its not that difficult a job. The soldering isnt very difficult as theyre just capacitors. The chassis is contained inside a metal container and has to be removed as a unit then opened up to get to the PWB PC board.
You can get a service manual at the following link, its also where they have the repair kit which contains the full service manual on the instruction CD with the Diagrams for the PWB PCB Kit.
They will email the service manual within minutes if you prurchase it. Here is the link.
http://servicemanuals.vstore.ca/
Where can a get a service manual.
I have the a similar problem except I am getting sound through my external speakers.
I have a little more to add to the story.
I purchased the TV in Feb 2005, in May 2007 I had the same problem (red light with no picture). After about 6 weeks of trial an error from a service tech, he replaced the Optical Engine and the Lamp Ballast (fortunately I was able to convince Mitsubishi to cover the parts even though it was out of warranty and I pad about $300 for labor).
Anyway, now we are in July 08 and when I attempted to turn on my TV today the red light came on. I replaced the lamp (which I had purchased in May 07 as I thought that was the original problem). But no luck, still no picture. It appears that lamp is not powering up, I took out the lamp and made sure it was in tight and tried again with no luck.
