Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
Posted on Dec 27, 2010
Cannot open the case on wd1600me passport - Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
1 Related Answer
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Mar 29, 2012
SOURCE: I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
1helpful
I have a WD Passport External Drive. (WD1600ME-01) I know it works but all the wires I have that fits the Drive don't seem to work. When I connect the wires, I can hear the Drive go on and shortly aft
You may first want to try disconnecting any other USB devices, to guarantee that the drive is the only power-drawing device. Drives typically need all 500 mA that a USB port normally provides.
Cables do wear out, especially those handled often. Mini-USB cables are pretty common and can easily be replaced.
WD Support Downloads My Passport My Passport Essential
Low format free software win7
There shouldn't be a need to do a low level format on a drive. Just use the built-in format in windows. If you really need one though, download the hiren boot cd and burn the iso to a disc. It has several low level format tools.
hope this helps
Hi im puneet frm karnal haryana . i want to knw how to do the on line registration of passport
This article is on how to apply for an Indian Passport Online. It must be remembered that you only register your India Passport application form through this process. But you must in any case visit your respective passport office, to submit the passport application form.The advantage of registering a passport application online is you do not need to obtain a token number for submitting the application at the Regional Passport Office. You don't even have wait long in the queue!!
Registration of passport application forms online can be made for the following.
Download in English (from passport.gov.in)
Download in Hindi (from passport.gov.in)
You are however advised to read all information on the website of your regional passport office before registering your passport application online.You can access these websites through the home page of passport.gov.in here and choose "Select Passport Office for Home Page" from the drop-down.
Next, go here and click Continue (at the bottom of the screen) to register your passport application online with the respective offices.
After registration, you will be asked you to Open/Save your application form. After Open/Save, you will have to print the application form. If you are not able to print the application form for any reason, you must note down the passport application number. With the help of this application number and date of birth, you can re-print the application form later. Note that you can also print the application if you have Saved the application.
After printing the passport application form, fill up the form and visit your Indian passport office to submit it. You will also have to pay the fee, and submit supporting documents such as date of birth certificate etc., along with the passport application form, on the appointed day and time. The date and time of appointment at your jurisdictional Passport office will be informed by the on-line system and will also be printed on the application form!
You should be at your Regional Passport Office, 15 minutes before the appointed time and Proceed to your respective counter. You can them submit your passport application form, along with all supporting documents and pay the fees.
2helpful
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC. when I connect it the drive light starts to blink and I hear a continuous...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
3helpful
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
The port of my Western Digital Passport damaged
You can open the case, and access the harddrive inside it. I found there are videos explaining the process on youtube. You can also find some info on Google. You'd then need either a USB SATA adapter, or a desktop computer with a SATA port that's not already occupied. Search for: western digital passport open case
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
