Contributor
- Posted on Dec 28, 2010
Re: My camera does not recognizes the memory card can not...
The card could be locked, there is a little sliding switch on the side of the card. Is the card formatted? Usually on a new card you have to put it into the camera and go through the menus to the format card menu.
Are you using the correct card?The camera will not read or write on a SDHC only the standard SD memory, the following are what it can use.
Type I and Type II Compact Flash cards
Microdrives
SD Memory Card, not the SDHC Card
MultiMedia Card (with the optional SD-CF1
What type and size memory card? The A200 uses type I and II CF cards, MicroDrives, and MMC and SD cards with the proper adapter. It will not, for example, SDHC cards.
