Question about Asrock 775i65G Motherboard
Mb 775i65g fsb 1066 fsb 800 dual core cpu i have problems of -when i use the default bios cpu freq (200 mhz , ram default )the pc starts and reboot just after thye fist screen and so.when i adjust cpu freq to 133 it seem to be ok but the pc never format correctly .. -nulti reboot during windows xp pro sp3 install
6ya staff
SOURCE:
mrsolution
steve quelnan
  • 70 Answers
SOURCE: it doesn't turn on
Try to reset the CMOS, remove the Battery on your motherboard, its like a silver flat coin, or if you can locate the RESET Jumper, just move the jumper to short. Then try booting-up your system again.
I hope this procedure will help you.
-mrsolution
Posted on Jun 11, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Posted on Aug 10, 2008
Anonymous
SOURCE: Asrock K7S41GX "NEW" does not work :bip-bip-bip
I bought the DDR333-PC2700 but does not work, three short signals. Other people have this problem, these cards have problems, hurts a lot. Now I have 3 new cards of order Please help me, I am a desperate Italian by marco2636@libero.it
Posted on Sep 11, 2008
Anonymous
  • 25 Answers
SOURCE: Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Posted on Feb 15, 2009
Anonymous
  • 203 Answers
SOURCE: core (TM) 2 duo processor E7300, socket LGA 775,
buy any motherboard BUT asus.
asus tech support is rubbish.
i run my system on an ASROCK motherboard.
excellent boards, 2500mhz bus, can handle any cpu, most have 4 ram slots.
Posted on Feb 25, 2009
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
My Acer Aspire 5520G will not play a Blu Ray disk. It keeps telling me that I need a critical update to the Acer Archade DVD playing software. When I click on the update button it comes back with a message...
from these derived specs You do not have a blue ray drive installed in this you have a DVD drive so of course a blue ray would not play in this unit. Specs are below from acer
CPU: AMD Turion 64 X2 TL-58, 1900 MHz [(9.5 x 200), L1 cache 64 KB/core, L2 cache 512 KB/core - dual-core, 64 bit support]
Motherboard Chipset: nVidia nForce 7000M-610M (southbridge), AMD Hammer DDR 2 IMC (northbridge)
BIOS Type: Phoenix
RAM: 2048 MB [667 MHz DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)]
Video adapter: nVidia GeForce 8600M GS, 512 MB GDDR2 [128 bit, core clock 600 MHz, shader clock 1200 MHz, memory clock 700 MHz - support for DirectX 10]
Monitor: Acer CrystalBrite 15.4" LCD (LG Philips), WXGA [8 ms/220-nit, currently running at 1280x800@60Hz] - HDTV capable
Audio: Realtek ALC268 @ nVidia MCP67/68 - High Definition Audio controller; Dolby Sound; audio jacks (on the front side): headphones, microphone, S/PDIF
Networking: nVidia MCP67/68; (wireless) Atheros AR5007EG - 802.11 b/g
Storage: Hitachi - 160 GB [8 MB cache, SATA, 5400 RPM]
Optical drive: Mats hita - 2 MB cache, DVD +/- R/RW/RAM/ROM, dual layer support, CD R/RW/ROM
Card reader: Ricoh - 5-in-1: SD, MMC, MS, MS PRO, xD
Webcam: Acer Crystal Eye (Bison) - 0.3 Mpixels
Connectivity:
4 x USB 2.0,
Broadcom Bluetooth adapter,
CXT Fax/Modem - 56K, V.92,
DVI,
ExpressCard,
IEEE 1394 (FireWire),
VGA,
RJ-11 (modem),
RJ-45 (Ethernet),
CIR (Consumer Infrared),
S-video/TV-out (NTSC/PAL)
Battery: Lithium Ion, 6 cells; (initially) discharge time ~3 hours
let me know
please do leave feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 08, 2010 | Acer Aspire 5520-5908 Notebook
My processor is rated at 3000 but is only running
What you are trying to do is called overclocking, and there are some excellent guides for that on the internet, like here: http://www.compunamics.com/overclocking.htm
I suggest you read this before proceeding the overclocking.
You can open the BIOS (press a key like F1, F2, F8 or del during startup). Somewhere there will be a menu with options for voltages and frequencies (units in V and MHz)
As you have read, processor speed depends on the multiplier and front side bus speed: CPU Multiplier x FSB = CPU frequency.
Right now, your frequency is 2200 MHz (presumably 11 x 200)
To get it to 3000 MHz (3GHz), you either have to raise the option called FSB in the BIOS to 270 (270 x 11 = 2970), or increase the multiplier to 15 (200 x 15 = 3000). Before you do so, write both the values down, so that you can reset to them, in case things go wrong.
I sugest first trying to raise the multiplier from 11 to 15. It may however, be locked at 11. If you can get it to 15, you're done, your CPU is now running at 3 GHz.
If not, you'll have to go through some more trouble.
First, you'll need to find your memory (or RAM, or DDR) multiplier and frequency, in the same menu as the FSB and CPU multiplier. Write them down as well.
As you have also read, increasing the FSB will make your CPU and memory go faster. This may however, be too much for the RAM to handle.
With the FSB frequency and multiplier, you can calculate the frequency of your RAM just as with the processor.
You will now have to change FSB from 200 to 270, so you'll also have to calculate a new RAM multiplier, if you want the RAM to run at the same speed.
For example, your RAM frequency can be 200 (FSB) x 2 (multiplier) = 400. If you then increase FSB to 270, your RAM will run at 300 x 2 = 600. You will have to lower the multiplier to get as close to 400 as you can get, and preferably lower, if 400 cannot be achieved.
Having done this, you can slowly start to increase FSB, I would suggest by 10 at a time. As soon as the PC has trouble starting, in the BIOS, increase the CPU voltage by one step, until it runs stable again. However, as your CPU is rated at 3GHz, you shouldn't have any trouble with this,and should not have to increase voltages.
If you encounter any probems, let me know!
Dec 15, 2009 | ASUS A7N8X-E Deluxe nForce2 Motherboard
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
Asrock 775i65G Motherboard Logo
359 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
