Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the agitator on a whirlpool ultimate care 2?
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Dec 27, 2010
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626614
Points
28464
Here is a video to show you how to remove the agitator.
5 Related Answers
Anonymous
  • 262 Answers
  • Posted on Dec 03, 2007
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Anonymous
  • 958 Answers
  • Posted on Oct 25, 2008
SOURCE: remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Anonymous
  • 324 Answers
  • Posted on Nov 14, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 18, 2009
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
washdryman
ROB CHRISTIAN
  • 154 Answers
  • Posted on Mar 01, 2010
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
3helpful
How do you disassemble the agitator for a whirlpool ultimate care ii?
i am assuming that you want to do that to replace the agitator dogs? this vidoe will show ya how to remove the agitator and replace the dogs.......http://www.youtube.com/embed/0GQh8JLqVv8" frameborder="0" allowfullscreen>
1helpful
How do I change the dog agits in the ultimate care whirlpool topload washer model lsr8233eq1
Remove number one then 23 then number 2
Then remove the agitator. Set it on the floor and yank it apart. Install the new part being careful not to break the retention tabs on the base of the agitator. Here is a nice video which shows how it is done:
More videos and a service manual are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
18helpful
2answers
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
1helpful
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
3helpful
Agitator is weak
you need to remove the agitator, then pull the top half off, replace the dogs inside the cam, and re assemble it, you can find a kit online for a few dollars.
Cant seperate the 2 pieces of my whirlpool ultimate care 2 agitator mod. lsq9544kocq
The following link should help you with removing the agitator to replace the dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Whirlpool models generally only have two methods of removing the agitator. One type uses a hex bolt, and the other uses a recessed square nut. The removal procedures are explained in the link provided. I hope this helps you. Please let me know if still have questions.
1helpful
Remove agitator on a whirlpool ultimate care II washer
tnx 4 using fixya,
drcool
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
