SOURCE: SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
SOURCE: Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
