Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a cannon Ixus 75 digital camera, which I have had for several years, and cannot get the date to print on the photo's. I have set the date and time as instructed in the namual, but when I go to the camera drop down menu, the "date stamp" option is not available [blacked out]. The camera serial number is 6133746477 if this helps
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Dec 27, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
219198
Points
3782
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again.
How do i get the date on my photo
The date and a lot more are stored with every photo in its EXIF metadata. Just about any photo viewing/editing program should be able to display this data. If you want to print it, please consult the documentation for whatever program you're using. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
2answers
Hi im using a canon digital ixus 9515 camera and I have the wrong date stamp on all my recent photos. How can I delete the date?
There is no way you can delete the date stamp from the photos you have taken.
For future photos you can either correct the date or disable insertion of date stamp.
I set the date and time then turn of the camrea then whe i turn it back on i have to set it again cannon 75
Please try to press the OK/Set button after setting the date & time. Probably you are not doing the same
1helpful
Canon Ixus 75: "Date stamp" does not work. I want to have time & date on the photos, but I can not do it. How can I fix this?
Image size (L, M1, M2, M3, S, Postcard) must be set to Postcard. Then make sure that on the Record menu Date Stamp is set to Date or Date/Time.
How do I turn the date stamp on canon ixus 75 ? want the date printed on front of my pics.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Hi how can i turn on date stamp on my canon ixus
Data stamp
Already replied in your another post.
Thanks.
Data stamp
There won't be...you can only get the date on the pic when you use POSTCARD setting.
Another suggestion would be to buy a Selphy printer from canon, and then you can select to have the date on the print.
Ixus 75
Your camera will datestamp your photos only in "postcard" mode.
However, the date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Display time and date on photo when its taken and printed
Hi, I have the same problem and I was told it works in a postcard mode. Try it.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
