SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I have a phillips 42 lcd and i have fios they both work fine with fios remote ill give you the phone number to call they will give you the remote code (412)497-7911 Call tommorow before 6 they will give it to you its verizon pittsburgh number i worked for fios for a few years...Please rate me when you get a chance..
Thanks,
Steve
SOURCE: 4 digit code for handheld remote control to program a Crest Universal remote control
Here are the codes for the RCP3 and RCP5:
RCP3 1023 1024 1074
RCP5 1014 1024 1074
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
SOURCE: remote not working after replacing
To check if the r/c is working...If you have a phone with a camera,look at the top of the r/c through the camera,you should see a light when you press any button,if not the r/c is faulty.
SOURCE: Strong 5405E set top box
Strong SRT 5006 Set top Box - how to unlock Channels so they dont require password everytime??
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems.
