Samsung YP-S2 MP3 Player Logo
A
Anonymous Posted on Dec 27, 2010
How do i fix my yp-s2 mp3 player when it is just showing solid pink-white
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1007
Points
Let the player sit and fully discharge over night. you probably got it wet. it should be OK in morning. if wet, place it in rice to dry overnight. then recharge. i have had this happen twice and this has worked.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
475
Points
My yp-S2 mp3 player is only showing a blue-green color where the light shines and its not playing music or anything, the light stays on, doesnt flash or anything, how do I fix it?
  • Anonymous May 11, 2012
    yea2 ,. i had the same experience too
My mp3 is not playing the songs.when start ,its do nothing.and when i push the button to fw. rw. or play ! just a beep is playing.
if samsung yp-s2, press with a pin in the reset hole to reset the device. chances are you are trying to play formats it does not support. try to stick with mp3 or ogg. some ogg formats beep like that too tho. it does not support drm windows formats
I do have my yp s2 samsung mp2 player.. unfortunately, my colleague had not remove it safely from the pc when i did charge it.. now, when music plays it doesn't produce solid sound unlike before... it...
I would suggest resetting it and seeing if that solves the problem.
There is a small hole in the body of the unit to gently insert the end of a paperclip to do this.
See page 14 of the manual for a picture. Get the manual via the link below.
www.generalmanual.com/MP3-MP4-Players/Samsung-YP-S2-MP3-Player.htm
8helpful
My Samsung YP-S2 Mp3 player can't be recognised by computers when I plug it in through the usb input (it used to work), therefore I'm not able to upload music on it anymore. How can I fix this bug?
Samsung Player Is No Longer Detected By Windows XP, Vista, Emodio Or
Samsung Media Studio.
When your computer doesn't recognize your Samsung MP3 player, programs
such as Samsung Media Studio (SMS), Emodio, Windows Media Player
(10 or 11) do not allow you to transfer files to your player.
In SMS and Emodio, the portable icon appears grayed out.
In Windows Media Player, you are prompted to connect a device.
Your PC may fail to recognize your player for a variety of reasons.
To begin troubleshooting, scroll down, and then click the operating
system your computer is currently running.
General Operating System Information
On Windows computers, Samsung MP3 players require at least Windows XP
Service Pack 2. If you have an older operating system such as Windows
2000 or Windows 98, your computer won't recognize your player until you
upgrade your PC to at least Windows XP Service Pack 2.
If your PC is running Linux or MAC, it will not recognize some MP3
players that support only MTP mode. However, it will recognize players
that support UMS mode and list them as mass storage devices.
The following Samsung MP3 players support UMS: YP-U1, YP-U2, YP-U3,
YP-U4, YP-U5, and YP-S2.
The following Samsung MP3 players support both MTP and UMS mode: YP-Z5
and YP-P3.
Windows Vista may fail to detect you device if the player is not
connected properly, Windows Media Player is not installed or has become
corrupted, Vista is unable to install the MTP drivers, or the MTP patch
is not installed.
You can check it out further by going to this website and entering the information about your player
http://www.samsung.com/us/support/#
Please rate me.
1helpful
Reformat the mp3 player yp-s2
While connected to the PC, go to my computer. Right Click on the USB Audio device (mp3 player) and choose Format. It will now format your player. Just make sure to back up your files first as to formatting will restore your player to default settings and will wipe out the memory.
Thank you for using Fixya!
2helpful
2answers
Samsung YP-U5 ipod installation problem
dont load crappy software that comes with these things,
windows generic usb storage device drivers works solidly.
just treat it like a flash drive, drag and drop your mp3s into the music folder.
and make sure its charged, i.e. leave it plugged into the computer for al least 30 mins
1helpful
2answers
5helpful
I believe the mp3 player is in repeat mode
Hi, Hope this User Manual will help you. I will post a link to download a PDF-File from Samsungs Hompage. Here it is, http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=no&CttFileID=1946269&CDCttType=UM&ModelType=C&ModelName=YP-S2QB&VPath=UM/200811/20081124173321359/YPS2-COMMON-ENGLISH2.0.pdf , You might have to Copy and paste the link in the addressbar in your browser.
Hope this will do!
Best regards Skeesy
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
