Ok the issue you more than likley are facing is simple.to solve. You need to check and see what resolution you can use, also there are many different encoding schemes for Mp4, so you need to ensure that each file is encoded with a codec that is supported by the radio. Check the user's manual first to see compatibility. Then reencode your videos to the proper size and format using a compatible codec. I would not think this radio has a scaler chip in it so more than likely you will need to encode the files in the correct resolution to match your screen size.Ok the issue you more than likley are facing is simple.to solve. You need to check and see what resolution you can use, also there are many different encoding schemes for Mp4, so you need to ensure that each file is encoded with a codec that is supported by the radio. Check the user's manual first to see compatibility. Then reencode your videos to the proper size and format using a compatible codec. I would not think this radio has a scaler chip in it so more than likely you will need to encode the files in the correct resolution to match your screen size.
You can't post conmments that contain an email address.
Your video files are not friendly with 9GAG TV. So you can convert your video to 9GAG TV supported video like popular H.264 MP4 format with Pavtube Video Converter .
Visit this guide to learn how to convert video to 9GAG TV supported video.
Maybe you have reported that AVI and some other formats not supported by Sony TV, in this case how can we play AVI files on Sony TV from USB flash drive? Please don't worry, now we will share the best AVI to Sony TV converter - Pavtube Video Converter with you, which can help you to convert AVI files to Sony TV USB supported format, and then you can play videos on Sony TV with compatible format.
Hello to all. Have twin boys staying over the holidays and they wished to view movies when they went to bed. have Polaroid 32" P32LED12 fitted to their bedroom. The tv is ok for playing dvd through it but when on using the usb drive with movies on it, it came up Invalid or Unsupported file. Have tried different movies with different formats and came up with nothing to play. So got myseld a video converter program: Wondershare video converter ultimate. On looking at the booklet from Polaroid, it says MPEG1.2, but although on converting the film to this format, the film broke up. So I took an AVI trailer and converted the trailer to all the formats on the converter and stuck this on the USB and stuck it into the tv. Out of all of them, i found that the converter format was VOB DVD FORMAT in this coverter. The film did not break up and the sound great. The film sizie was a bit smaller in frame size but this can be increased. What the converter showed after the conversion was: DVD-Video/ Format: VOB. Video Codec: MPEG-2/ Audio Codec: MPEG-2 audio. There is a settings on this converter at the lower right corner, but you can fiddle with this yourself. But to finish with, I have tried most of the films with different formats and could not get them to work on this tv, so get yourself a video program converter, put in laptop or pc and convert film to VOB. Hope this helps as there is nothing in any help on google for this tv.
Make sure that your handset supports mp4 videos. You can play 3gp videos in your handset. If your handset supports mp4 videos, then set your mp4 video's frame rate, bit rate and resolution.
That means the files in your MP4 player is not at the right format. you can use a leawo mp4 video converter to deal with that problem. i have used one for a long time to convert videos to mp4 for my devices.you can have a free downlaod of it.
It looks like this device only supports MP4 videos encoded with H263 format so you'll need to get the video converted to that format before it'll play on your GTC3300.
The PSP only reads mp4 type video files. You cannot use youtube videos directly on the PSP. However, there is a way to convert them. You can click into the following application. I have this myself, so that I can convert flash videos to MP4 format to play on my PSP:
You just convert from youtube to mp4 format with the program above and transfer the mp4 file to your PSP and it will work just fine. You can download a free demo of the ImToo program, but it will convert only up to 3 minutes of video.
The viewty will play .avi (divx) and MP4 files providing the display resolution is not above 320x240. If the the display resolution is above this for either format, you will receive a "file type is not supported" error. Please be aware that the viewty CAN play Divx .avi, Xvid .avi, .3GP and MP4, but only if they are not above that resolution.
it means u put a wrong video format psp will not accept. u have to convert the video file to mp4 so that your psp can play, and u can try this video tool, then u can watch the video on your psp after correcting the format. http://www.pavtube.com/video_converter/
