The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called
Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more.
Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a
Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configuration
hope this helps
John
A google ad'. for some software entitled 'Driver Magic', I downloaded and ran it. The result was a blue screen crash. I was not best pleased. I am sure that your company would not like to be associated with this sort of rubbish and will take some action to ensure that it ceases.
Thnk you for the solution to my problem. Excellent result.
