Question about Canon ZR100 Mini DV Digital Camcorder
I have a CANON mini DV ZR100 and on the fold out screen underneath the battery symbol there is a red flashing image with a slash through it. what does this mean?
    New Friend:
Your Button cell back up battery is dead. If you remove you main batter you will see a smallflip door towards the top of the cammera. Replace the Cr1616 button cell battery. Without this battery your camera will not remember the current settings like the date. Batteries are available for $5 to $7. Quick and easy.
Posted on Mar 13, 2011
I get a flashing red warning symbol during play and record. It is on the bottom LHS of the screen just above the 'camera shake' indicator and looks like an oval with a back slash through it. This symbol is...
i think it's the button cell that's CR1616 that's hidden when your battery is in the camcorder. Remove the battery to reveal that little plate to replace your button cell. It functions properly just that time and date might not be recorded.
Jan 02, 2011 | Canon MV940 Mini DV Digital Camcorder
Image wont come up on screen and its flashing me and saying the batery needs charging its like theres a cover over the inside of the lense. There is a red symbol with a red line through it. Is this the...
No. The power converter inside the camera is damaged some how. It says the battery needs charging because power cannot get to the main circuit - it needs to be taken apart and isolate the crack or open contacts.
Nov 24, 2010 | Canon MV700i Mini DV Digital Camcorder
ZR80 Mini DV Digital Camcorder: I have a blinking red icon with a slash through it...
Sounds like the memory battery indicator. Does it look like a button battery with a slash? If it is, you probably cannot set the date and time also. It takes a CR 1616 button battery and goes in the window behind the main battery.
May 16, 2010 | Canon ZR80 Mini DV Digital Camcorder
Have an IX1s Canon camcorder. Flashing red screen icon.
it means a particular battery is low or out of the camera, which hold the date and time memory of your videos. don't worry it doesn't affect your any recording or playback of videos. I have one and is blinking from past one month. no issues at all.
Dec 06, 2009 | Canon XL1S Mini DV Digital Camcorder
I have a zr100 camcorder and I have a red flashing icon underneath the battery icon. It looks like a boat with a diagonal line through it with an arrow to the right of the line.
On page 24 of the manuel it shows the symbol that you mentioned below the battery symbol. It's labeled item 4. Which states "flashes in red when the lithium button battery is not installed, or when it needs replacing". I guess you need to check the lithium battery with a voltmeter to see if it's any good.
Dec 04, 2009 | Canon Video Cameras
There is a red flashing symbol on the screen
If there is a red symbol that flashes at the bottom of the screen, it means NO CARD. No more images can be taken. For more details refer page 101 in the below link.
https://anna.nscad.ns.ca/help/canon_zr70mc_zr65mc_zr60mc.pdf
Nov 05, 2009 | Canon ZR60 Mini DV Digital Camcorder
Everytime i turn on my Cannon Camcorder GL2 theres a red blinking cursive with a slash and a plus like object thats on top of the slash. what does that mean?
Backup battery needs to be replaced. It's fitted behind a small square panel under the fold out LCD screen. The battery type is CR2025.
Aug 28, 2009 | Canon GL2 Mini DV Digital Camcorder
Flashing red icon on LCD during recording session AND playback. cam works fin but what is it?
Behind the regular battery is a door to a lithium "coin" battery. It needs to be replaced (if it is even in there.
May 04, 2009 | Canon ZR100 Mini DV Digital Camcorder
Red blinking on screen.
This symbol indicates that the backup (date/time) battery CR2025 needs to be replaced. This battery is held in a holder that slides out from the bottom of the camera. Pages 8 and 104 in the manual (available here) detail how to do this.
Dec 11, 2008 | Canon MV30i Mini DV Digital Camcorder
Black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
Dec 08, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
334 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
