Few days ago I fix my problem of E:91:01 by initializing. Then It was OK. But yesterday when I tried to take a picture first not able to take. After turn off flash I can take the picture. Five minutes later E:91:01 again blinking in the screen. I again tried to initialized it stops but 2-3 minutes later it again blinking. I tried several times this circle continues.
SOURCE: problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
SOURCE: dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
SOURCE: no sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
SOURCE: TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
SOURCE: Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
My sony cyber shot dsc-w40 is flashing error code E:91:01. How do i fix it? I know it's got to do with my flash and i can still take some normal pictures, but if i need the flash then i can't. please help
