IF THE MODEM GIVEN BY CENTURY LINK is 660 Series then the IP Address of the Modem and Router Will be the same
So before starting the troubleshooting ... Disconnect the centurylink Modem from the Belkin
Step 1 : Connect One of your computer to the belkin ( to any one of the 4 grey ports ) with an ethernet (CAT 5 ) Cable
Step 2 : Open internet explorer
Step 3 : On the address bar type http://192.168.2.1 and press enter
Step 4 : If you are at the belkin Router Setup utility ..
Step 5 : On the Left under LAN Setup click LAN Settings
Step 6 : Leave the Password blank and click submit
Step 7 : Change the IP Address to 192.168.3.1
Step 8 : Click apply changes
Step 9 : Connect the Modem - Router ( to the yellow slot )
Step 10 : Check the color of the light in the Router
Step 11 : If it is solid green .. Check if you have internet
SETTING UP A WIRELESS NETWORK
Even though The router comes with a Pre-Set Wireless network many people wont like to use it
if you like to setup a connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
SOURCE: I received a 660R modem
Please see the attached manual for the centurylink router and modem. There is a section discussing RIP direction. Normally it is set to none because it assumes the centurylink unit is your router. Change that setting to both and then reconnect your router and see what happens.
The link for the manual is:
ftp://ftp.zyxel.com/P-660R-61/user_guide/P-660R-61_3-40.pdf
If this works, please indicate so with your response. If not, then provide more information about what you have tried and how you are trying to set everything up.
Good Luck.
