Question about BUFFALO 10" Bench Grinder
I have an B-6CB(KS) 6" buffalo grinder, the switch
    Brigadier General:
  • 4,088 Answers
The neutral line should never be switched--only the hot wire (black). If there are only two wires that went to the switch, you should be able to tie them together and the motor will run when plugged in. The switch should be a common SPST type either toggle or rocker to fit. Hope this helps!
Posted on Jan 10, 2011
6ya staff
SOURCE:
Replace missing switch on bench grinder
2 wires are not needed to use they are the wires of an supression capacitor on the switch then there are 2 wires from your power cable and 2 that goes to your motor that 4 you only you have to use you can also connect the 2 wires from the s-capacitor with te wires on the motor together thats is how its also correct, (but best is to remove it because its only for suppression for FM ukw radio signals and everybody has DAB+ and the change to have short-circuit is reduced.
Sep 30, 2015 | Bench Grinders
On/off switch buffalo bench grinder
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Nov 20, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Need a new switch for buffalo grinder model B-8CB
That entire older Buffalo line of grinders: N-10CB, B-8CB, B-6CB, bgbr-6cb all use the same push pull switch. Most of those grinders were dual-voltage with a starter capacitor and there are 6 wires connected to a 4 contact switch. The "Jet BGS8-076" grinder switch that is used by the older Buffalo's, Galaxy, Duracraft and TestRite grinders is no longer available.
The good news is that there is a replacement switch from another manufacturer: "3030-9001 push pull switch for RDX grinders" from Wholesale Tool is a direct replacement. It has the same 4-screw contacts on the back and the same push-pull diamond pattern front plate.
Sep 21, 2013 | BUFFALO Grinders
I need an on/switch for a 6inch buffalo grinder model #b-6cb cycle 60 1/2 hp voltage 110 amb2 3450 rpm serial#8587745
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
Aug 30, 2011 | Grinders
Model #: B-8CB Serial #: 840417 need switch assy
That entire older Buffalo line of grinders: N-10CB, B-8CB, B-6CB, bgbr-6cb all use the same push pull switch. Most of those grinders were dual-voltage with a starter capacitor and there are 6 wires connected to a 4 contact switch. The "Jet BGS8-076" grinder switch that is used by the older Buffalo's, Galaxy, Duracraft and TestRite grinders is no longer available. The good news is that there is a replacement switch from another manufacturer: "3030-9001 push pull switch for RDX grinders" from Wholesale Tool is a direct replacement. It has the same 4-screw contacts on the back and the same push-pull diamond pattern front plate.
Aug 10, 2011 | BUFFALO Grinders
Starting coil switch I had to replace a bearing on my buffalo bench grinder and I cant figure out to put the starting coil switch back on or how it works
A coil is just that a coil and unless it has diodes it doesnt matter how you put it on. let me know (diodes are those things that are usually black with a silver stripe -cylindrical in shape)
Jun 23, 2011 | BUFFALO Grinders
Need a switch for Buffalo grinder model B-6CB(P) serial #841224. Are they available?
That entire older Buffalo line of grinders: N-10CB, B-8CB, B-6CB, bgbr-6cb all use the same push pull switch.Most of those grinders were dual-voltage with a starter capacitor and there are 6 wires connected to a 4 contact switch. The "Jet BGS8-076" grinder switch that is used by the older Buffalo's, Galaxy, Duracraft and TestRite grinders is no longer available. The good news is that there is a replacement switch from another manufacturer: "3030-9001 push pull switch for RDX grinders" from Wholesale Tool is a direct replacement. It has the same 4-screw contacts on the back and the same push-pull diamond pattern front plate.
May 03, 2011 | BUFFALO 10" Bench Grinder
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
NEED ON/OFF SWITCH FOR BUFFALO BENCH GRINDER MODELB-6CB-1/2 HP 6 '' 110 VOLT
You can get a replacement toggle switch at any hardware store look in the electrical department.
Jun 10, 2009 | Grinders
BUFFALO 10" Bench Grinder Logo
720 people viewed this question
Top BUFFALO Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Tom Chichester
Are you a BUFFALO Grinder Expert? Answer questions, earn points and help others
