? 5:11
https://www.youtube.com/watch?v=aiWwA6bXvhE
Nov 30, 2010 - Uploaded by Turbo231
Installing/Replacing rear speakers in a 2002 Pontiac Grand Prix GT DIY ... same as a 2000 grand prix ...
? 17:50
https://www.youtube.com/watch?v=pIxGeqy9QYI
Feb 26, 2014 - Uploaded by Can't Kill Me
How to remove back speakers and install in a 98 02 Oldsmobile Intrigue. Can't Kill Me ... 6x9 Rear Car ...
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
1994 Mazda Protege Car Stereo Radio Wiring Diagram Car Radio Constant 12v+ Wire: Blue/Red Car Radio Switched 12v+ Wire: Blue/White Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Blue/White Right Front Speaker Positive Wire (+): Blue/Red Right Front Speaker Negative Wire (-): Blue/Yellow Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Blue/Red Left Rear Speaker Negative Wire (-): Blue/Green Right Rear Speaker Positive Wire (+): Blue/White Right Rear Speaker Negative Wire (-): Blue/Green
Here are the colours of the factory radio harness and what they do. 1995 Toyota Camry Car Radio Installation Schematic Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Power Antenna Trigger Wire: Black/Red Car Stereo Amp Turn-On Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Tweeter Size: N/A Car Audio Front Tweeter Depth: N/A Car Audio Front Tweeter Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Purple Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Blue Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
1999 Ford Ranger Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Yellow
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
pls rate because noone has been rating hope this helps
Firstly, remove the centre lock nut on the stem. This loosens the stem/headset. Pull the handlebars up and rest them next to the front wheel, make sure the brake cables aren't being stretched too much.
You'll see there is a locknut on the headset (at the top of the frame/top tube where you pulled the stem from) and loosen this (might need a massive spanner!).
Pull offthe toppart of the headset, ball races and lower part. Replace with the gyro bottom and top parts. Grease the ball bearing if they aren't already!
Slide it together, fit the stem and you'll notice the brake lines that come with it. Undo the rear brake, run the splitter cable from the front lever to the top half of the gyro, same with the bottom half. I found putting some padded stickytape on the bars helped here as the splitter cable would 'ting' off the bars.
Undo the front brake and run it through the stem hole, through the forks and cable tie it to one fork leg.
Test the brakes, adjust where necessary and on you go pulling bar-spins for fun. Please don't land a jump with the bars half spun, it hurts....a lot!!
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
